1 - 3 of 3 Posts
Will this turbo work for my mods. a hx40 its 8 blade compresor wheel and IND: 2.36" or 59.94mm
EXD: 3.27" or 83.06mm
Trim 54.8
Here is turbine wheel messurement 3" V-band IND: 2.99" or 75.95mm EXD: 2.52" or 64.01mm I converted from inch to mm with my fone.
Garrett T3 Flange
Should be fine. Will give you room to build on too. Be careful though, Ive heard if you "bark" those hx40's that you can snap the turbine shaft.
Depending on what turbine housing it has, it may be a little laggy for your fueling. It's a copy of a Hx40 CHRA with a Hx35 turbine housing.
1 - 3 of 3 Posts
