1 - 20 of 34 Posts
does the motor seem to crank over slower?
Reactions: rcp2f
Yes check the batteries. It takes a LOT of CCA's to start our trucks. When it does start see if the volt gauge goes straight to 14+ or stays under 14 untill you get above 18mph.
From what I understand, the grid heater is not required for it to start at those temps. Someone correct me if I am wrong tho. Hopefully it's the batteries. If not, I'm not sure. My truck did the same thing and finally quit starting period within a few days, regardless of outside temp, and it ended up being the injectors:banghead:. Keep us updated and good luck. Oh yeah, is it throwing any codes?
No its not required at those temps for most trucks. BUT every truck is different. I have gone on trips up north in the winter and a couple of times the girlfriend would just start the truck without waiting(about 0-10f) and mine has always started right up. Although there are some trucks that do not want to start unless it is plugged in. Could be a number of things like the FCA, CP3, injectors, lift pump, or a hole in the rail and causing the fuel to go back. It is one of those things where you can't really tell over the internet.
Reactions: rcp2f
If the grid heater is working I would say you have an injector problem. I would try and run some injector cleaner through first, but most likely you need to send your injectors to DDP to have them tested.
Reactions: rcp2f
Discussion Starter · #19 ·
I have been running stanadyne injector cleaner in every tank for the past month, and I use two tanks a week. Before that I used diesel kleen every 2nd of 3rd tank. I appreciate everyones help. If anyone has any ideas please let me know.
· On a new learning curve!
Any white smoke in the mornings or ruff idle? These are signs of failing injectors.
Reactions: rcp2f
1 - 20 of 34 Posts
