What year???? 2WD or 4WD???My garage is 82” high from floor to seal. Will a Ram 2500 4x4 Cummins fit? My current truck is a 1997 F350 4x4 standard cab gasser; stock height on 285/75r16’s, and it clears by a few inches.
82” is 6’ 10”It’s going to be a super close fit.. my truck measured 6’8 stock from what I remember ... 82” is 6’8.. to close call.
82” is 6’ 10”
OP: I’d wager it fits, but the easiest way to find out is to either go measure a stocker at the dealer or test drive one to your garage and look.
FWIW my 3500 lifted 2.25” on 37’s is a touch under 84” to the cab lights.
You may have missed the part where I wrote 4x4. And since this is the 2013+ group; there’s that, too.What year???? 2WD or 4WD???My garage is 82” high from floor to seal. Will a Ram 2500 4x4 Cummins fit? My current truck is a 1997 F350 4x4 standard cab gasser; stock height on 285/75r16’s, and it clears by a few inches.
Good question- I can adjust the door up, but that 82” measurement is to the frame seal with the door pushed all the way.can you adjust the door to go up little more?? a lot of the time they stop below the frame height. just need to adjust the stop on the garage door opener
Ah, when you said seal I thought the one on the bottom of the door..........Good question- I can adjust the door up, but that 82” measurement is to the frame seal with the door pushed all the way.
Well.....since this indeed is the 2013 Forums, it could have been a rear leaf-sprung 2013 2500 OR a 2014 & up rear coil 2500.....and there is a difference. I was going to send you a link to RAM’s dimensional pages.....but I have seem to have deleted it. :|You may have missed the part where I wrote 4x4. And since this is the 2013+ group; there’s that, too.
2015+ on the year, though- would want to stay as new as I can comfortably afford.
