will a cummins 5.9l fit in a 1986 ramcharger
Thats right you will need a diesel trans one because it won't bolt up, 2 beause if it did bolt up it would probably last a week. Gasser have high end torque mean they get there max torque a 3000rpm were diesels have low end torque and they get there max torque usually 1800rpms and lower. Thats what will tear up the trans.None of the gasser 727's will not bolt to the cummins engine adapter. You need the diesel auto trans.
The 518/46Rh is a fully hyd trans. All it needs is a signal wire for OD.
The 618/47RH is a lockup full hyd trans. All it needs is a signal wire for converter lockup and OD.
:lol3:any engine will fit into anything...The only things you have to contemplate is whether your hammer is big enough, your grinder is big enough, and your welder is big enough....everything else just falls into place
For the gentle aproach :woot::lol3:
If it don't fit make it fit. Weres a bigger hammer.:lol3:
