it will fit, has different size injector holes depending on year and are prone to cracking.
First gens are 12 valves.If I remember right, the exhaust ports are a different shape from 12 to 24 valve, and a disadvantage will be having fewer valves.
You have to do that on some '94-'98 2nd gens too.you have to cut a notch in the head for the ofv on the ppump
I have a limited slip, or posi-traction, whatever you want to call it in the front. I arranged the clutches to be aggressive, so it locks up quickly. In 4x4 mode, it works well, turning is OK. It is a bit of a battleship to maneuver, the regular cab helps. I did not put in a front locker because of turning issues, especially in mud, snow or ice. In sand or soft dirt, I can feel the front end wander a bit as the wheels search for traction. The truck goes almost anywhere I care to point it.Baja i was wondering how your truck turns in 4x4,in your sig you have frount locker or limeted slip,not sure witch.
