Nope its because it takes a real man to own a 6.7 and we end up putting the filters on too tight to begin with.:hehe::hehe::hehe:cause Dodge/Cummins hates the owners of the 6.7's....and wanted them to only go to the dealer to do fuel filter changes :doh:
that's my guess
What he said. :w: :w: :w:Nope its because it takes a real man to own a 6.7 and we end up putting the filters on too tight to begin with.:hehe::hehe::hehe:
Do you oil the gaskets on your oil and fuel filters before installing?I've changed my oil several times and my fuel filter twice and I always just install them hand tight. I had a plastic filter end cap socket for my oil filter and it broke last night trying to remove the oil filter, so I bought a metal Lisle one today and it removed it after a lot of struggling.
The last time that I changed the fuel filter I put it on as tight as I could with my hand and this time I had to drive a screwdriver through it again to remove it....I tried using the 3/4" drive but evidently I didn't have the correct arrangement of extensions because I couldn't get it in there.
Any tips? I'm getting frustrated and every oil/fuel filter change is becoming a PITA
Maddram;2559808 The last time that I changed the fuel filter I put it on as tight as I could with my hand and this time I had to drive a screwdriver through it again to remove it....I tried using the 3/4" drive but evidently I didn't have the correct arrangement of extensions because I couldn't get it in there. [/QUOTE said:I think the fuel filter uses a 1/2" drive to remove it. If you were using a 3/4" drive, that would explain why you couldn't get it in there.
I have one of the strap type filter wrenches. So far, it has removed everything I've tried it on.
Somewhere I read something about the design of filters that they tighten up while in service. Maybe I was just dreaming, but it sure beats getting loose while in service!
bought the same thing a month or so ago. FANTASTIC!! draining the water is a 10 second, clean & easy job. better filtration and cheaper than oem filters too.I resorted to this after a similar fuel filter experience. Never again:thumbsup: Its available at dieselpowerproducts.com
I use the same one, there's no filter on the farm that doesn't come free with this unit. I love it.I found a neat oil filter "wrench" at Sears. It has three arms that are geared so they swing around and tighten on the end of the filter as you turn the 3/8 inch square socket receiver. The metal arms grab the filter TIGHT and very easily remove the filter using a ratchet with 3/8 extensions.
