1 - 12 of 12 Posts
Post up if your running a fuel plate and if so what kind. I was a bit hesitant, but when i put my pump in i just left the plate out. the fuel is more controllable than my vp and throttle response is awesome. just curious on what you more experienced p pump 24v gurus think about this.
Got P7100?
0 plate full forward, so from what ive read its the same as no plate. i have it in there in case i want/need to limit fuel for some reason(hasnt happened yet though).
Boiler up!
i was told to always run a plate, no matter what. i run a 0 full forward, starwheel cranked. lots of smoke, hard to clear up with my turbo too.
I didn't run a plate for about a month, but put in a 0 full forward just in case I wanted to tune down a little for towing, so far it's all good though 10,000 pounds of skid loader is the biggest thing this truck will see and as long as I take my time getting up to speed it runs fairly cool
old thread here but any of you guys have flow numbers with and without a plate? if a 0 plate is the same as no plate why even bother with grinding it or buying one then?
I think like everyone esle said, just in case you need to detune a little for some reason, it gives you that oppurtunity to do so
Got P7100?
this
grinding is free:thumbsup:
but no plate and a "0" plate are the same?
Banned
No. If you run a 0 plate full forward it would have no limit on rack travel, like it would run with no plate. You can pull the 0 plate back to limit rack travel if desired.
i run no plate :) but my truck is also a race truck. wont be towing anything with it cause all that good stuff is off the truck.lol
okay thankyou.
now is full rack travel is that when your only at wot?
I run a zero plate. The difference is about 250hp between full forward and full back. As long as your afc isn't gutted I don't see where running without would be a problem.
1 - 12 of 12 Posts
