So my '16 Tradesman auto didn't have this noise, but my '15 Laramie manual makes this "whooshing" rushing air like noise which starts up behind the dash/gauge area within a few seconds of starting the truck. You only notice it when idling, it sounds like the blower motor does when the HVAC is on 4 or 5. Any ideas? Thanks.
Low coolant and it is making the noise going through the heater core.
Thank you. I assumed that was all on the passenger side, but your reply led me to go check my coolant level. It was right at the Min. line so I added maybe 1/2-3/4 of a quart of OAT and will report back after driving to work tomorrow.
Reactions: v10sport
Topped it off, no change. It almost sounds like smooth static from the left dash speaker...but it's not.
In case anyone stumbles upon this and wonders if I found the problem. I did...embarrassing as it is...there was no problem at all. It's the noise made when the vented seats are on.
