1 - 3 of 3 Posts
i just installed a bradford built bed on my truck its the dual spear bed same as the regular bed just has toolboxes and the spears in the back my problem is the fuel fill neck what did you do with yours did you get the sump kit from bradford built and did you use your original filler neck if you did or didnt can you get some pics of the underside to show how you did it my truck is a 02 3/4 ton 4x4 longbed diesel filled tank before took old bed off but now need to be able to fill again when i start to drive the truck:confused013::confused013::confused013::banghead::banghead::banghead:
the bed is all powdercoated so i really dont want to weld or torch on the bed i can cut a hole i have a big hole saw bit kit up to 5" i can use but i just wanted to see what others with one of these beds has done
1 - 3 of 3 Posts
