1 - 19 of 19 Posts
Im thinking of putting a 255/85/16 on my pickup, does anybody out there have any pics or advice for a 33 inch tire?
285-75-16 Goodyear Dura Tracs. 33" tall, 2" leveling on the front. Tires rub on the rear part of the front fenderwell when there is suspension compression. Going to add a 3" body lift:
33x12.50x16.5 and what i believe no lift, factory 6in blocks and 7 leaf spring pacs all around, it will rub a little in a hard turn and in a touque.
Darwin
285/75R16's on stock rims, suspension all factory, the only time it rubs is because i have a fender flare that is loose (not from the tire rubbing on it, just cause my fender is rusting out on the driver side)
These are 255/85r16 bfg mud terrains
and these are 305/70r16 Firestones on 16x10`s
If you notice, the flares are off, because the 305`s/saggy srping combo was causing enough rubbing to start damaging the front portion of the wheel opening when turning into a driveway, they rubbed pretty good. without the flares no rub but I`d like to get it level one day.
Thats the best pic of the important fender i have right now... They are 285/75/17 MT ATZ's. The only thing that rubbed was the small tit that comes off of the flare from the factory.. i cut them off because you cant even see them from the side of the truck..
I'm running 285/75/16 (33 inch tall) on my mess with 7 inch wide wheels. All stock with original sagged springs. No rubbing anywhere.
Discussion Starter · #11 ·
YAll have some nice trucks out there, how do you think it would affect mileage?
I'm getting about 16.5, mostly in town and gravel road driving.
I get between 20 and 20.9 on mine, but I drive softer than anyone I know. I suspect there might be cobwebs in my turbo no more often than I build any boost.
I have 285's on mine too and they don't rub at all but they're worn out. I also want to go with 255's but think my 9" wide rims might be too wide for 255's.
i run 255's on mine they never rub but i also had the springs re arched in front . planning on going to 315's . sorry no picks. as for milage average about 18-20 a tank commuting with a heavy foot.
do you have a lift on that truck?
Not really, it has a re-arch and an add a leaf in front. It sat a good 1-2 inches higher when I 1st bought it 20k miles ago but it IS time for new springs...too bad they arnt free :rof
1 - 19 of 19 Posts
