1 - 11 of 11 Posts
i have a 94 3500 dually 4x4 five speed and i was wondering what would make it sputter and then puff out white smoke? i changed the fuel filter but that only helped a lil bit and then when it gets warm it helps alot also
air leak.... lift pump could be bad that will do it. There is a primer plunger on your lift pump, it has rubber over it feel around it really good for fuel. If it has fuel leaking there the pump is bad. If you replace that also replace the 90 rubber hose that goes from the lift pump to the fuel heater canister.
Chances are that is your problem
The plugger on the lift pump is black rubber it sticks out on the end of the pump. It is on the lift pump not the p pump. The lift pump is down on the block below the fuel filter.
1 - 11 of 11 Posts
