1 - 14 of 14 Posts
my hopes and dreams of compounds, twin fuelers, injectors ect.... aint gonna happen.
so now I have a chance to buy a steed speed 24v 2cnd gen t4 with 2.5 external gate option and a turbosmart 45mm hypergate hp , both new/ unused from a friend at work changed plans. I can get this stuff quite a bit less then the steed alone would cost new, smoking deal.
so I'm looking at an s363 for my 2003 ho. other mods will be head studs, 50-100 nozzles, valve springs, fass 150, arsen/victory,udc tuning and the trans is already built billet everything.
what do you think about either BW Airwerks 63/68/.88 ar undivided t4 or 63/68/.91 ar divided?
or other suggestions.
Could run the 0.83 housing too.
I run the 83. Seems to be working. Jus sucked somethin thru my turbo tho so a wicked wheel is goin on. Gunna see how it does after that
· Diesel sniffer
Just an fyi, AR's between T3 and T4 housings are not comparable. An AR of .8 in a T3 is much tighter than a .8 in a T4.
1 - 14 of 14 Posts
