1 - 16 of 16 Posts
I’m going to be performing a transmission service on my 68rfe, I figure I might as well install a deep pan with a drain plug while I’m at it.
The Revmax pan is the one I was looking at, as well as the mag-hytec. Are there better ones you guys are having good luck with?
Or do I stay with the stock pan and weld a bung on it for a drain plug? I’m ok with that if the deep pan is not a worthwhile addition.
I did the Magtech on my 07. I'll do it on my 17 when the time comes.Worth it if only for the gasket.
I started out with just an added bolt-on drain plug on the stock pan, and that was okay but not great.
I finally went all in and got the mag-hytec pan and it is very nice, looks pretty tough under there and sort of matches the finned AAM rear cover I put on my truck.
The aluminum pans are kind of tough to maneuver on and off the trans due to the spin-on internal filter hanging down, that and the cooler lines make clearance very tight.
And, the mag-hytec has it's drain plug on the bottom, so when you pull it to drain the fluid, it gushes out super fast.
All in all, I would make the same choice if I had it to do over again, the mag-hytec is a high quality casting and is machined and painted super well.
When I did my first and only (so far) filter/fluid service on my 2014 68rfe, I installed a PML pan and used a lube locker gasket. No issues and its been leak free.
Joe @ Dude’s Diesel Performance
Mag-Hytech and RevMax both make nice pans. Mag-Hytech holds 3 quarts over stock and the RevMax holds 4 quarts over stock. Mag-Hytech will be a little easier on the wallet as well.
On call 24/7
Goerend makes a nice pan. I always thought the derale pan with the tubes was kinda cool too but not sure they make one for 68.
I do like the Mag pans but if it goes 60K with the factory pan it can go another 60K with it. Not sure it helps with cooling at all.
Not sure on the 68RFE, but on my 48RE mag-Hytec had two size sumps. a +1.5QT and a +3.5QT (as I recall.) I opted for the 1.5QT for clearance.
Pan had been great though the hex head bolts are a PITA sometimes. I thought about replacing them with torx, but will be selling soon so I'm not going to bother.
I'll take an allen head over a torx every time.
I did the PML raw casting and sprayed it black with some engine paint I had in the garage. I used NAPA filters with their gasket...no leaks.
Sent from my moto g(6) using Tapatalk
If purchasing a Maghytec Deep Pan what would be needed in addition to that. Also what would be a good gasket to use. 2018 68rfe.
I used the lube locker gasket on mine, self sealing and supposed to be reusable.
1 - 16 of 16 Posts
