1 - 2 of 2 Posts
Ok I need someone to take me to motor school a little bit. I'm in the planning stages for my up and coming chev conversion. I'm curious about which motor would be the best combo of easy install, efficiency and power. I don't need a power monster but like any other guy I do like to tinker and tweak a bit. I'm hoping for around 500-600 hp. It will be a daily driver and tow vehicle only occasionally towing around 10000lbs.
In my research I have found that the 12v is easiest to wire from the lack of computers etc. I would assume that the older you get the easier to install but can I get too old to be worth trying to get that kind of power.
Also I would ideally put an Allison behind it so any info on that install and adapters needed would be great.
Thanks in advance. :thumbsup:
Master of Mayhem NASFIG
The best 12v is the 94 to 98 and if you really want to break it down 96 to 98 for the better p-pump.
1 - 2 of 2 Posts
