1 - 17 of 17 Posts
I just bought my truck this past fall and im ready to start adding some mods. What I wanna know is what air dog pump to put on my truck with the mods i plan on adding in the future. I just ordered a set of gauges...egt booste and fuel pressure. I plan on ditching my d-box and getting a smarty and later stacking the smarty with a quadzilla. Im gonna stick with the stock vp44. When i have the money i plan on going with a different turbo possibly twins . My tranny is fine as of now and it does already have a aftermarket clutch. So really what i wanna know is what size air dog pump do i need to support all the fuel that the smarty and the quadzilla will be able to deliver. Also if you have and suggestions to what I should do modification wise Im open to ideas....thanks in advance.
A 100 will support that and more. If you think you might want go crazy with other mods later you could go with the 150 for insurance.
Check out the FASS platnium 150 its this best value on the market IMHO/
I was thinking a air dog 150. If i get this lift pump what types of pressures should i be seeing at idle and at WOT.
Go with a AirDog 100. It will do everything you need it to do. The install is much easier too.
They run about 15 out of the box, but the kit comes with a slightly heavier spring that makes it run about 17. I like to run the higher pressure.
Okay well what fuel pressure should I see?
I have the 150 on mine and it works perfectly. I maintain 16 psi all the time.
Discussion Starter · #11 ·
Its a long bed
i see 18 at idle and 5 to 0 wide open,still cant figure that out
That's strange, mine never goes below 12 no matter how hard I'm on it.
My FASS has never been below 15. If it ever went below 14 I would be upping the pressure. It run 18-19 at idle with a new filter.
I am about to get a airdog 100..any installation tips?
Install is simple on the AirDog 100. The main tips I would have would be more vehicle specific. Every truck is a little different tips for one truck may not relate to the next.
1 - 17 of 17 Posts
