The port right next to the map sensor? that's just capped off?
that's where mine isThe port right next to the map sensor? that's just capped off?
mine too its a 3/4 inch pipe plugthat's where mine is
Correct plug... The 1/2" pipe plug is a coolant passage...mine too its a 3/4 inch pipe plug
im kinda wonderin that toowere do you mount it on a 12 valve?
Yeah those work but becareful the bolt can snap off rather easy...I think you can buy a bolt from Geno's Garage that replaces one of the grid heater bolts. Thats what I would do for simplicity. i don't have analog gauges though.
Didn't know that thanks for the info. You just want to tighten it a 1/4 turn before it breaks then back it off a half a turn.:lol3::lol3:Yeah those work but becareful the bolt can snap off rather easy...![]()
Remember its just a thin hollow bolt like the banjo bolts... They break just the same...Didn't know that thanks for the info. You just want to tighten it a 1/4 turn before it breaks then back it off a half a turn.:lol3::lol3:rof:lol3:
