I see a lot of Q&A on wheel offset.
Just want to throw this out there as a resource. Best wheel offset calculator I've found.
https://www.wheel-size.com/calc/?wh...-20X8.5ET44&fcl=20mm&scl=20mm&wcl=30mm&sr=0mm
Plug in your numbers and measurements and it will give you all the data points including any change in scrub radius. The only thing it's not going to help with is bumper clearance.
I used this for wheel/tire fitment on my Audi last year and it was spot on moving from factory 235/45/R17 to a different wheel & offset and 255/35/18's.
Obviously it can't cover all the variables if you're going extreme or have modified suspension, but it covers a large percentage of the "will it fit?" questions.
