1 - 11 of 11 Posts
That's the sound my truck is making when I start out. It sounds like wet boots on Linoleum.My most likely candidates are:
1) U-joint (never had one squeek, just clunk)
2) Wheel bearing
3) Diff pinion bearing
4) Something in the rear brakes/park brake?
Any ideas? Any of you guys have a similar sound? I can't hear it after 40mph/64kph; my exhaust is too loud. Thanks in advance.
Yes sir :agree2:
I third the u-joint.
I say stop driving through wheat fields :lol3:
Check your carrier bearing on the rear driveline also, they almost always squeak when the start going bad.
Discussion Starter #10
Survey says.......the center bearing and one u-joint. The shaking finally got so bad I had to cover a spot on my icy driveway with plywood and take it like a man. I'll get the other 2 when it gets above freezing. As it was, we had a late February heat wave at -3C/26.5F/270K.
Thanks for the replies.
I could hear mine when backing up a slight grade with the door open.
How'd you bypass the reverse honk??? Not trying to hijack.
Wood
1 - 11 of 11 Posts
