1 - 15 of 15 Posts
2001 24 valve
WANT TO ADD..
edge with juice
150 Injectors
62mm turbo
Add a boost elbow at the wastegate
Airdog 150 gph
Breather
AMSOIL air filter
2 smoke stacks.. 6 or 8 inch?
What do you think about this setup? Its a daily driver. Will this put a strain on my transmission? About how much HP do you think I will end up with? MPG?
Maybe smoke the sun out?:drool2:
god yes it will kill the trans if it's a auto, the clutch if it's a stick...:doh::doh::doh:
fill out yer sig so we know what we're workin with...:thumbsup:
2001 2500 6 speed 24 valve
Right now it is completely stock
its a manual so I will need a new clutch..
what would you reccomend?
Sorry about that
yes i meant edge juice with attitude
and yes i will also have some gauges
Thanks
· Future Fly Boy!
juice comes with all the gauges you need...and youll be a little under 500hp cause that HO pump sucks...if you had an SO, somewhere between 500-520 ...and yes, get a clutch before you add the turbo and injectors..
What would be the most efficent psi to run with the 62 turbo?
G
i would either get a sbc dd 3600 or 3850 and get the upgraded hydrualics i have driven my truck with both pressure plates and didnt really notice a difference if you ever plan on sled pulling i would go with a 3850 but 3600 will do just as well and shift a little quicker
Discussion Starter · #11 ·
okay due to money..
im gonna start with the exhaust and the edge.
Will i need to get a new pump for use with the edge? Will I be able to run the edge without a new clutch?
· Banned
I would upgrade my Lift Pump before the Juice
I agree with lucasb man....get a lift pump before you do anything....
:ditto: :ditto: :ditto: :ditto: Best thing for our trucks. :thumbsup:
1 - 15 of 15 Posts
