The bodies are the same. The nozzle is 8 hole on 03-04 and 5 hole on the 04.5+.
Yes, you can use 06 bodies, with your 03 tips. Tips are not interchangeable, just the bodies.so I could use 06 injectors with my 03 tips?
03-04 injectors are 8 hole, 04.5-up are 5 hole. Angulation and spray pattern are different, put the wrong injector nozzle in, and spray pattern and angulation is significantly different, you will melt down an engine. Pretty sure warranty work would be a hell no, on that one!Thats good to kno. I never knew this. Good info.:thumbsup:
