A couple of weeks ago I posted I have a 96 12 valve that was knocking. I cracked injectors one at a time and found # 6 to make the knock go away. I was going to swap injectors around to see if the noise followed but decided with 225k on the clock new injectors were in order anyways.
Fast forward, the new injectors are in and truck still has a knock on # 6 but it will go away when you crack the line.
I will get guages on it in the near future to see what the fuel pressure is but I am assuming it is good as the truck pulls really hard through all RPM ranges.
P-pump next step, or what? could a weak pump or bad return affect only one injector? the truck runs perfect and idles smooth.
If it is something in the pumo on # 6 is there anything that can be checked or done with the pump in the truck?
I am tempted just just let my son live with it but it bothers me a lot.
Thanks in advance,
David
Thanks in advance,
David
