1 - 9 of 9 Posts
Cummins Fanatic
Just recently bought a Miller HT 3300 tilt bed trailer. Can anyone tell me the weight rating on this?
Cummins Fanatic
Discussion Starter · #2 ·
Bump... Anyone?:w:
looking for a response in 12 min is a little over the top......look at the tag that came on the trailer, that will tell you
Yep, Should be a VIN plate somewhere and should say the gvw.
Cummins Fanatic
Fill Diesel Only
what options are you seeing? A bit more info would help. I would take a chance and guess it will be the largest number on there.
Cummins Fanatic
Heres what the tag tells me:
MFG Date 2-81
VIN 1MZHT1822
Model HT-330
GVWR 13,400
GVWR Each 5350
Trailer Weight 4000
GVWR 14,600
GVWR Each 5840
Capacity 10,600
Which number do I go by??!!
I would almost need a pic of the tag....looks funny. But if it says capacity is 10.6k and weighs 4k then I would go with the 14.6k.....makes sense, but what i believe are the axle ratings don't seem to jive?!?
just my 2 cents
MFG Date 2-81
VIN 1MZHT1822
Model HT-330
GVWR 13,400
GVWR Each 5350
Trailer Weight 4000
GVWR 14,600
GVWR Each 5840
Capacity 10,600
trailer weight 4000, capacity of trailer 10,600 total gvwr 14,600 that should be total gvwr.. i believe you should be able to tow 10,600 weight limit on that trailer..how you register the trailer is different and cost is based on gvwr at least in fla.
hope it helps.. good luck
1 - 9 of 9 Posts
