The reason i have a cummins is for reliabilty so i dont want to jepordize that part, but i would like more towing power
How much Boost and HP can a stock engine take
The stock Non I/C injectors are good to about 375rwhp, not the I/C injectors.This is what I have been told or found out through searching threads... maybe people will argue with some of my numbers.
The Stock A518 is good to around 225 whp, if you replace the TC with something decent, add another 75 whp.
The stock H1C is good to about 250-300 whp, the GDS compressor upgrade is good to about 320 whp for towing, more in a truck that doesn't tow.
The stock lift pump (if it's healthy) is good to around 225 whp
The low pressure piston lift pump is good to about 350 whp.
The high pressure piston lift pump (the one on the P7100 trucks) is good to around 450 whp
The stock injectors are good to around 375 whp (via turning up the pump)
Hope this helps you out.
