What would your next course of action be after the tunnel ram/horn?
1 - 19 of 19 Posts
· DieselAutoPower.com
I'm thinking for spring (after I dyno the truck with the tunnel ram and better tuning) I'll be going on to the next phase. I've listed a few things above. Tell me what you think...
Oh and to expand on the twin parallel vgt's. I think I'd use a microcontroller with a pressure transducer to drive servos. The servos would control the vanes. I'd be ditching the entire electronic setup from the factory.
· Future Fly Boy!
id like to see you tinker w/ the vp itself and see what (if anything) you could come up with...i think rollincoal messed with his, but i dont know what the results were:confused013:
i voted for the twins though...i think that and some 200's would be a great addition
I'm hoping in a few months I might start tinkering a LOT more making some custom fab stuff. My step father plans on setting up a shop in their house (next door). He used to be a machinist for northwest airlines. So I hope we'll pool resources to at least come up with a nice sized lathe, milling machine, and I really want a TIG welder and plasma cutter.
· Mule Barn Proprietor
I think you don't know what the actual results were because the results weren't very beneficial.
I voted Twins...its an obvious choice...AIR VOLUME
I like the s475
I loved the water with my twins and ill run it again, helps with spool up and gives you a little more go. Even with twins it helps keep the egts down while towing. But thats just me
I would go with a s475 under your he351, run an external wastegate to help with dp and you will have a fast spooling set of twins with lots of top end
i said twins but thats the setup im going for.....
I say twins with a s475 but would like to see Twin parrallel vgts
go twins and get some FBD 7x12's or 7x14's
· Vendor
I'd like to see you do something with the VGT if it is within reason.
Twin VGTs would be badass, but HE351/S475 is a great setup and I think it would get you to 55 psi with less hassel.
1 - 19 of 19 Posts
