I have a hy 35 now and want to upgrade. just want to know whats good. Is the hx 35 good and will it bolt in I took the hy and put in the hx?
G
a hx35 really wont be much of a upgrade i would at least get a 62/71/14 it you get a different turbo for your truck
Future Fly Boy!
the hx is a little larger than you hy and will keep things bit cooler...it will also bolt straight up...if you dont plan on doing anything else w/ your truck, that will be fine to do...a lot of guys here are getting good deals on hx40's, which is a bit bigger...you would need a fueling mod to spin it though and make sure you get one w/ the correct flange...you would also need a new downpipe...what are you plans ultimatley for the truck?
I want to put some 100hp sticks in and not sure if I want farm boys or coaltrain I heard both are good.Im putting in the big line kit with a walbro pump next week.
G
if you dont plan on going any bigger than 100s i would just pic up a hx35 for cheap 100s match really well with a hx35
