ok, ive done the reading and searching through threads and ive decided to just ask and see if you guys have a preference of what to run.....Edge Juice/Attitude with ???? i dont really want or NEED anymore power, just would like to have more smoke, especially if i run the 5in exhaust with the 6in mitres.....
03 3500 2wd Dually 145,000mi, Edge Juice/Attitude, intake, Im pretty sure now its just a stock downpipe and 4in.(too small) mbrp exhaust.
also another question,
sometimes when i lay into it, the Edge will start hollering and telling me to stop...its boosting up to and over 38psi, what should these trucks run?? is it possible that i have a boost fooler and dont know it?? i bought this truck at the auction last week and all of this was already done, thats why i dont know exactly mods.
any imput would be appreciated...:popcorn:
If you aint 1st..Ure LAST
can't really tell ya on the boost problem but 38 is about the limit. but stakin smarty is a really good stack but if you didn't want too much power just get an mp8 and stack with smarty. or keep edge and stack diablo sport. my buddy did that and got great milage. with the edge one 1 and diablo on tow/economy.
Tech Specialist
if your running a stock auto, your gunna need to beef it up before you start stacking or it'll slip like a greased up hog.
:agree2: Also the edge juice on the 2003-2004s does duration, pressure and timing so it is not the most stack friendly on those years.
Discussion Starter · #5 · (Edited)
thanx for the info....
not to sound too stupid, but does "not friendly" mean knock? or just screw the truck up in general???
Well if you stack it with a pressure box you could have too much pressure and crack injectors, if you stack it with something that does timing you could blow your head gasket. You could stack it with something that only does duration but watch those EGTs!
Discussion Starter · #7 · (Edited)
ok, if i go the route i want, and my wallet allows me to, 4" or 5" in. tbe with 6" stacks, im sure that would help the egts... but would it help enough??
is their a programer that only does the duration???
I know you can get a low timing PPE tuner. Also you can run the smarty without the timing advanced.
