What the heck does "c-code" mean?
19107 Views 5 Replies 3 Participants Last post by  theBurlyone
Help trouble codes Galore!
Hey guys, I was doing the key trick in my parents 2004 2500 and it went through its thing and near the end it said "c-code" and then came up with a few different numbers. but they were spaced apart like, "69 24" (That wasn't one of them) I don't have them here at the computer. Does anyone know if these are trouble codes or just nonsense?:confused013: I'm a 24 valve guy so help with a CR truck would be greatly appreciated!:thumbsup:
Also the first two numbers of the code are the same each time you do it but the second two numbers change every time with no specific sequence.
come on guys I know you're online and I know you've looked at this. If you don't know just say "I have no clue" it would at least show me that you want to help
I would say it's error codes because mine has always said no codes or something like that. I would do the key trick again and compare them to the sticky for codes. Good luck!
http://www.cumminsforum.com/forum/3rd-gen-powertrain/54121-error-codes-2003-3rd-gen-trucks.html
From doing a simple google search it comes up with alot of info on C-codes.If there is no number following a c code you will need to get a scanner and plug into the ODB port.
Heres alist od C code errors.
C-Codes - DODGE RAM FORUM - Dodge Truck Forums
Thanks for your help guys. Well I've determined that the numbers do move in a specific order. it looks like this:
c - code
41 07
64 33
00 00
it always ends with the 00 00 and then starts again. Basically 41 and 64 are always the same. The other two numbers are always different. But they move up one odd number at a time. So the next sequence is:
c - code
41 09
64 35
00 00
and yes I know how to use google but I could search for hours there or just ask the people who know the answers (usually) but always have advice at least.
Yeah I'll try that, thanks alot!
