at what temp is it normal to plug in the engine heater?
thanks
thanks
I hope not, I've plugged mine in when it's in the low 20's and left it plugged in all night before. Not often, but once or twice.I plug in below 50* just for instant heat, how long do y'all usually leave it plugged in? I've got a timer on mine that starts heating it at 4 am and I get in the truck about 6am and its pretty toasty by then.
I've been told leaving it plugged much longer then that can ""cook"" the motor by overheating. Any truth to that?
Sent from AutoGuide.com App
Cool figured it was an old wives tale lolNo the element wont cook anything. Usually gets the coolant to about 100 degrees. Some days at work we have our trucks plugged in for 3 or 4 days before they get used.
When I was really busy with the Fire Dept I use to keep my truck plugged in 24/7 and leave it like that even into the summer time so the warm up period was as short as possible. The coolant temp at most might get to 120*F max that I've seen but the biggest down fall is the cost of power to do this. Since now I don't run as much I just use the high idle system to warm up the coolant to 100*F and roll on. I totally skip the block heater all together.
Here in Idaho it roughly 6 cents a kilowatt hour. So 24 hours times 0.75 kilowatt so its roughly $18 bucks a day to run a block heater.good question
I wonder how much electric they use per hour
So roughly I'm paying about $2 a day to have a toasty warm truck first thing I. The morning.... I can live with thatHere in Idaho it roughly 6 cents a kilowatt hour. So 24 hours times 0.75 kilowatt so its roughly $18 bucks a day to run a block heater.
Hence why I would rather use high idle than a block heater.
Opps! I screwed up the math...So roughly I'm paying about $2 a day to have a toasty warm truck first thing I. The morning.... I can live with that
No. You will just have a warm ext cord and a high elec bill !I plug in below 50* just for instant heat, how long do y'all usually leave it plugged in? I've got a timer on mine that starts heating it at 4 am and I get in the truck about 6am and its pretty toasty by then.
