1 - 10 of 10 Posts
So I'm getting ready to upgrade from a stock turbo soon, I pull my truck in a street class which limits us to a 2.5 inlet. So I'm gonna be getting a 62mm probably a non waste gate housing to save some money since I'm fire ringed and studded already, I have a drag comp, 150hp injectors and the hot rod pump, I have a 1600 degree egt gauge that I can max out like nothin right now, obviously, I'm trying to figure out to go with a 12 or a 14 size exhaust housing. I do use my truck for work and tow over 10k a decent amount of time, I think I have enough to fuel to spool the 14 without to much of an issue with a trailer but wanted some other people input
The 12 spools FAST. The 14 should be pretty close. If you are in the high rpms a lot go with the bigger housing to decrease drive pressure.
How competitive do you wanna be pulling? I wouldn't be running a s362 if I was pulling especially if they allow clipped wheels.
I'm not really looking to be super competitive. How I'm running now I placed 4th out of 12 if I wanted to be more competitive I'd leave 33s on my truck but I like 35s I mostly just pull for the fun of it, I'm happy aslong as I'm not last and don't break but yeah I think that's what im looking at getting and with a billet wheel, I was just wondering people's thought as far as the 14 housing for towing I know it spools slower as long as it's not too bad I'm good with it
just curious why you'd rather have a non gated ex. housing, I would look into a 62/71/14
well I was only looking into the non gated housings because I have head work done meaning firering and head studs so I can push more boost without blowing the gasket, i had luch with the guys at the shop i go to and we were talking and they suggested the non gated because i don't need it and a gated one id just end up plugging off anyways but i could save like 6-700 by getting the non gated housing but they called me later today and said the only ones there was were t4 flanges and our pulling rules say t3 only
There are two very good non-w/g turbine housings, .76 T3 and .85 T3.
If your going to be pulling, you want a T4 housing. My suggestion is to try a BorgWarner s464/83 with a .90 or a 1.00 housing.
Discussion Starter · #9 ·
i would but our rules state that we need a stock size appearing housing, the inlet size cant be larger than 2.5 inches which they do check and im 99% positive they say t3 flange only
1 - 10 of 10 Posts
