1 - 10 of 10 Posts
I got a 08 6.7 all mods in my sig...this is my 1st 6.7l I've had 3 other 5.9s...I'm not sure if I should go injectors/nozzles next/turbo upgrade/cp3 upgrade/ or head studs 1st? I would like to go nozzles but will the stock turbo or cp3 take it?
Thanks for any help, also I'm not new to the forum just forgot my password
^^^Agread. And efi or mini maxx custom tunes will always benifit you. If you are not planing on more than 700hp a s366 is half price what a s467 is and I love it. I cant hit more than 1360 egts on 1/4 mi run with daves tune he says should be 600hp. Got my s366 at Ducky fuel Inj for $500 and deff cheapest ive seen.
ΔΔΔΔΔΔΔΔagree with most of what the other two said but do head studs before turbo or more fuel.a blown hg will set you back a bit for sure.
2018 Ram 2500
Air before fuel. And if I was you, I would do the injectors and head studs at the same time. It's easier, fyi.
I did nozzles on injectors that had 80k miles on them and they've held up great. Im at 92k now.
when I started my build I did my fuel upgrades first because it was easier and cheaper parts. but I regreted it. I was constantly baby sitting my egts and I rolled coal every where, I had to really watch it so I didn't piss people off. I would definitely do head studs. I did my nozzles, rockers, springs and pushrods all at once. you don't have to, but beefing up your head is sure insurance. and head studs are a must.
when I finaly installed my compounds 62 phat shaft/s474, everything pulled together but it was stressful for awhile. I hit 55 psi at wide open throttle now but the volume of air moving is insane. air first though. long story short.:rof
Thanks for guys...you think do in the 2nd gen manifold swap is the way to go or just change out charger? I'd really hate to lose my stock exhaust brake
1 - 10 of 10 Posts
