1 - 4 of 4 Posts
Looking at getting a 5th wheel toy hauler (12.5K GVWR) and wondering what extended RPM range is good for the ol' Cummins.
Can I tow in OD on flats? At 65mph, in OD, my RPMs are about 17-1800. Is that a good RPM if I tow in OD? At 55mph with OD off, I'm about 2200.
Also, what speeds do you guys tow at on the open road?
Thanks very much, Mike.
i wouldnt recommend ever towing something that heavy in OD, itll cook you fluid and shell your trans in a hurry!!
These Dodge tranny's must be crap then because my Powerstroke would tow my 18k 43 foot toyhauler forever in OD. I towed it across the country from AZ to FL 4 times in OD. Makes me wonder if the Dodge is going to be able to pull it after hearing that.
Thanks for the replies. If I don't tow in OD, what would be the max sustained RPMs to tow at?
1 - 4 of 4 Posts
