That's me. With my Smarty it's got so much low end power,that seems right. If I extend the rpm's way up there it results in blacking out anything behind me.I usually shift between 1500-2000...
A good friend of mine who is factory trained tech told me these trannys aren't meant to be shifted w/out clutch like you can is a class 8 truck. I try and refrain from it.When you can shift it without the clutch is always a good sign...
Same with mine it smokes in 3rd and 4th if I shift above 1700. 1400-1700 is my shifting range. Now if I'm getting on the Interstate I'll shift out of 5th at 1800-2000. No coal.That's me. With my Smarty it's got so much low end power,that seems right. If I extend the rpm's way up there it results in blacking out anything behind me.
I have NEVER tried clutchless shifting in my truck and never will.A good friend of mine who is factory trained tech told me these trannys aren't meant to be shifted w/out clutch like you can is a class 8 truck. I try and refrain from it.
I'm assuming the reason for the high rpm coal is too small a turbo. My friend gets tired of the smoke deal,and will unload his Smarty and just use his Edge w/o Monitor. Runs hotter,less down low power but way more mid and high throttle power. Nowhere near the smoke as Smarty also in any rpm or load situation.Same with mine it smokes in 3rd and 4th if I shift above 1700. 1400-1700 is my shifting range. Now if I'm getting on the Interstate I'll shift out of 5th at 1800-2000. No coal.
Well my turbo is probly the same one as yours. If I'm running freeway speed and have to roll into the throttle to change lanes it will smoke then too.I'm assuming the high rpm coal is too small a turbo. My friend gets tired of the smoke deal,and will unload his Smarty and just use his Edge w/o Monitor. Runs hotter,less down low power but way more mid and high throttle power. Nowhere near the smoke as Smarty also in any rpm or load situation.
I didn't know my truck had a catalytic converter on it. :confused013:Moparman,since you're in Texas,coudn't you just remove your cat and install a test pipe(temporarily of course)? With my old 98.5 w/Mach 1.6's and Edge EZ I could smoke pretty good but like this boy. Same load,gears and a DTT on the old one.
Yes every 04.5 and on diesel truck has a cat from the factory. I am in TX and I just removed mine with a cat back. No problems yet from the cops. Our trucks do not require emissions(at least where I am) and is just a safety test. I am sure some places are more strict than others.I didn't know my truck had a catalytic converter on it. :confused013:
You mean your testing your cat right?Yes every 04.5 and on diesel truck has a cat from the factory. I am in TX and I just removed mine with a cat back. No problems yet from the cops. Our trucks do not require emissions(at least where I am) and is just a safety test. I am sure some places are more strict than others.
