1 - 14 of 14 Posts
Washington Chapter Pres.
I just want some opinions on what I should do next to my truck. See sig for details. Any input would be appreciated. Thanks
Austin
how far do you plan on going w/ the truck?
imo, i think an Airdog should be next mod, reason is even w/ a stock truck your still gonna benefit from it w/ better throttle response, better MPGs, more HP and longer CP3 and injector life.
I'm shooting for around 550 HP at the moment.
For 550 on an 03 you'll need a Fuel System, Clutch, Turbo/Turbos, 90hp Injectors, Smarty, and a Pressure Box. That should give you plenty.
Ok. So I'm thinking that a lift pump is next right?
Ran a FASS or Airdog . there are a lot of threads on both of them. good luck from an 03 guy:beer
Discussion Starter #8
Ok. So FASS or Air Dog? 95 or 150 GPH?
sorry that was "run" a FASS are Airdog:thud:
150 for that much power, gives you room to grow:peelout
Discussion Starter #11
Discussion Starter #12
Now should I just get the HPFP or HPFP with filter housing?
818
Get the whole system with filters. I will not only filter, separate the water, it will also separate the air in the system which can cause damage. It is a great system.
You could always just move air better first
and
1 - 14 of 14 Posts
