what kind of injectors should i get i want some that will puch black msoke but i dont want them to be rediculose in price
id invest in a good lift pump and gauges before you start punching yourself for blowing up your stuffwhat kind of injectors should i get i want some that will puch black msoke but i dont want them to be rediculose in price
:ditto::ditto:I gotta agree, get a lift pump and guages before you even think about injectors. But when the time comes, FBD has great prices and great quality products
Sold 14 sets on Saturday at the TS Sled Pull event.I gotta agree, get a lift pump and guages before you even think about injectors. But when the time comes, FBD has great prices and great quality products
I'm a big fan of DDP's. But I would adress the lift pump so you have plently of fuel to feed those sticks.Coaltrain, Fireball Pro's, New Era, DDP just to name a Few.... you dont want to skimp on quality
James
RSD
The 14cm housing is gonna take a bit more to spool than the 9cm housing you used to have. Does the HX35 have and adjustable boost elbow on it? If not, it probably just your wastegate opening like its supposed to.:thumbsup:I just finished putting a hx35w 14cm housing on my truck and now my boost numbers are in the 22-24 range and it a little doggy is it time for bigger injectors to help booost the turbo? the old hy i could get up just past 30 but towing with it the egts would get high i dont want to overfuel it and end up right back to square one is there a good injector that wont kill my egts with this set up.
also just installed 3 piece manifold new intercooler tubes and cfm intake elbow.:confused013:
Like he said it will be slower to spool with the 14cm housing, if you add more fuel its probably gonna get warm when towing.The 14cm housing is gonna take a bit more to spool than the 9cm housing you used to have. Does the HX35 have and adjustable boost elbow on it? If not, it probably just your wastegate opening like its supposed to.:thumbsup:
Very nice Gus!! :headbang:Sold 14 sets on Saturday at the TS Sled Pull event.
