1 - 16 of 16 Posts
what is this and why dont i have it?
I dont have it either, but its kinda under your left battery. Not sure why some are there, or on the engine.
That is the APPS, or otherwise called the Throttle Position Sensor.
I believe that on the manual trans trucks they were put under the dr. side battery tray until the 05 years, then the APPS was mounted right on the gas peddle in the drivers compartment.
They are on models before the 04.5 change. They just get in the way
Skrew- EPA CARB OPEC PETA
My early 04 does have it
where did you find that pic? that truck has some crazy wiring! i wanna find out more!
Banned
its gay, and it freezes up and makes drivin very difficult, i fawkin hate it, id like to rip it off and burn it
Discussion Starter · #10 ·
i found it on google lol
Reactions: Drshunter
TECH SPECIALIST
you could weld 2" plate steel on a ship with those battery cables.
must be $25 a foot.
mb72
put a small truck heater blanket on it
""its gay, and it freezes up and makes drivin very difficult, i fawkin hate it, id like to rip it off and burn it""""
If your truck is an auto, then it was mounted to the cyl head, like i the picture, because it had the trans kickdown cable routed to it. The manual trans trucks were mounted under the dr. side batt.
My 2003 6spd had the apps mounted to the cylinder head to.
my mannul 03 has it on the head too!
03 CUMMINS
my early 03 is also
I have only seen them on the 03-early 04's. All of them mounted to the cyl head, auto or manual. My buddies 04.5 auto doesn't have it and my 05 6sp doesn't have one either
1 - 16 of 16 Posts
