I have a tube like that coming down through but its to drain the water outta my fuel canister thing, perhaps the same thing your tube does. Or its an overflow tube for anti freeze or something along those lines
That hose is the drain for your fuel water separator. There should be a yellow lever on the side of your fuel filter canister that would allow you to drain the water from that canister.thanks all. I'll just leave it be then.
I bet the wife gets pissed when she finds the sock in the laundry every few months!!! :hehe:yeah its the crankcase breather, if it is dripping, on my 01 I attached it to a short piece of garden hose then put a sock on the end of it and tied it out of the way, the sock soaks up the oil and every oil change you just put a new sock on, helps to keep the underside of the truck clean.
