1 - 13 of 13 Posts
I am trying to fix battery parasitical losses and took dash lower apart to find the click sound when batteries are hooked up.
The click sound is coming from the BCM box . ( i did not know i had one until yesterday)
But, this thing is mounted with one screw next to it.
It does not look like a dodge part, no Chrysler part number.
the wiring is all professional too like factory
What is it?
ISSPRO makes aftermarket gauges...someone musta installed ISSPRO gauges in your truck at some point in the past. That is a sending unit that converts different signals from different probes to the actual gauges.
Are the gauges still installed in the truck?
If not, and if your not going to replace them,. no reason not to disconnect that box.
I'll bet you could call ISSPRO and ask them any questions if you have any concerns about it.
OH...OK.
Thanx!!
ISSPRO pyrometer electronics.
Ya KNOW you are senile when you can remember what ya did 15 years ago....LOL
Reactions: seafish
LOL , yes I have to now write myself a recommendation!
I have owned this thing so long and replaced and so much.....It is like a family member on rehab.
There is always a way to squeeze another thousand bucks out of me
Reactions: Andy2500
I knew that looked familiar! That's a transducer for an Isspro EV pryo.
Cable Electrical wiring Gas Electricity Wire
Discussion Starter · #10 ·
I still have the gauges---The EGT and boost have always worked well, the Fuel P gauge is very moody.
We called that a transducer (changes from one analog signal to another) in my previous industrial process controls life. I still have the EV pyro somewhere and a 40? psi boost gauge in a homemade pod. I probably still have the probe, somewhere, too. I had that stuff on my 03 til I got a TST PMCR with that really nifty little key pad/monitor.
Reactions: jkidd
2006 2500 4x4, spinny wooshy thing, bigger sticks, toothpick trans, wallet weight reduction mod.
You got the flux capacitor model from Chrysler?!?! Jealous!
Discussion Starter · #13 ·
Mostly just the shaft.....It is now gold plated
1 - 13 of 13 Posts
