1 - 13 of 13 Posts
mine runs 193-195 usually. I saw 200 the other day, but I was on the skinny pedal pretty hard.
i rarely tow, but from cold it will go up to 206/209 & back down and stay between 197-203 all day, running hard or not
I live in Texas, once the thermostat opens initially at around 208, it runs between 197-204 all day with no load. And that's in 105 heat all day.
The older 6.7s like mine had a 190* t-stat. I think the newer ones have a 200* one. Mine run right around 190 give or take a couple degrees when warm.
It was over 100 today and with the cruise set at 75 mine stayed at 207 to 210.
My truck runs about the same everyone else's. In the lower to middle 190 degree range, just driving normally and cruising on the interstate. I saw it hit almost 200 degrees, after installing my Mini Maxx, and trying out a few extended, back to back, pulls on the highway, just to see what boost the truck was hitting, and to get a feel for the power.
Decoder Ring Specialist
2011.5 and up are hotter tstat and a heavier pressure cap...normal for me is 200-206. Once in a while it'll drop down to 195 when the tstat opens and the coolant in the radiator is still really "cold"
Reactions: no_more_strokin'
Now that its summer, I'm seeing 195-210 on average.
Last few weeks, its been ~98F here.
Truck cools down pretty quickly and usually averages 195-198F.
1 - 13 of 13 Posts
