i did 505/1000: drag comp, mach 4's(150 hp) and a ps 62/65/14.Ok im wonderin what kind of numbers i will be layin down in the 00-02 not sure if it will be H.O yet. with these mods
5inch exhaust, guages, clutch, fuel system, intake, Adrenaline, 150hp jammers, and a bigger turbo.
Sorry, missunderstood! :beernot with my ford with the new dodge im gettin. LOL
i would stud it if you going to make over 40psi of boosti didnt think i needed studs untill like 600hp? How hard are they to change in a cummins. What turbo do you guys recomend.
when they get the ADR to peak hard like the drag comp, it will be a much better all around chip. quad did just come out with some new tunes that i have not tried yet. i will have to try them out and see if they hit harder. so in the end, i believe the ADR will be the one to have.Oh and is the Adrenaline better than the edge?
