1 - 20 of 23 Posts
Just curious to know if rebuilding a turbo is something that you can do in your own garage effectively with hand tools and a kit, or is this something that should be left to the pros? Is it really cost effective to do it yourself rather than ship it to somebody? And if its not, who knows a good turbo rebuilder?
Discussion Starter · #2 ·
also are aftermarket turbos tougher to get rebuild kits for than stock holsets?
Since I'm not set up for balancing & shaft straightening, I send mine to the local turbo shop.
Don't have to press anything?
Sent from my DROID3 using Tapatalk 2
It's pretty easy. Just a few c-clips and bolts and clean everything.
What about balancing and such? Are the rebuild parts relatively universal or are they manufacturer specific?
· Sasquatch
If you're just replacing seals then you can do it yourself, but if a wheel is damaged and needs replaced then the turbo needs balanced, at that point it is better to have the turbo rebuilt by a professional.
Discussion Starter · #9 ·
I'm assuming you've rebuilt a few turbos, and that they run great without being balanced?
It's not that you're not balancing it. It's just that you need to install the wheel back together in the same position compared to each other. That way you don't need to rebalance it. This way it stays balanced. You need to mark the compressor wheel to the shaft so it goes back on exactly how it came off. It's really simple.
The only thing I've ever had an issue with is getting the compressor wheel off. And for most people it comes right off. For me, I had to heat the piss out of it with a heatgun, set the turbo up in a vice, and gently work the shaft down using the vibrations of an air hammer. Again, I was being VERY gentle. An air hammer has less of a chance bending the shaft than a regular hammer and punch.
Just pull it apart being sure to lay the parts out in order, clean everything up with mineral spirits, sand blast the outside of the housings if you want/can, and reassemble the same way it came apart using assembly lube on all the bearings and shafts
Also, make sure you mark the housings to the center section if your not reclocking it. That way everything goes back together in the same orientation it came apart.
Thanks BLinindoll.
One thing I'd avoid is any sort of bead blast....that stuff gets everywhere and hard to completely clean.
Discussion Starter · #12 ·
Well I called the company who made the turbo and they said did not allow anyone to make a rebuild kit so I would have to send my turbo to them... which probably is around about way to say they wont tell me whether a garrett based rebuild kit would match their turbo lol.
Yep.. they want the business. That stinks. :doh:
· President of the 509
What kind of turbo do you have and what is wrong with it?
Ive took a wheel off of a good turbo and replaced my ate up wheel with no problems...Took the compressor housing off, zipped the nut off with an impact, replaced the wheel, and zipped it back up tight.
Discussion Starter · #16 ·
Hight Tech Turbo 62. Nothing is wrong with it, its just a couple years old, figured a bit of maintenance wouldn't hurt it.
Discussion Starter · #18 ·
Lol, if nothing is wrong with it don't touch it. I ran my HX35 for 10yrs and it was still perfect.
yea thats what people have been telling me lol. I guess if its not broke, don't fix it.
Exactly! Don't touch it! If it aint broke, dont fix it!
You're asking for it without balancing.
1 - 20 of 23 Posts
