what gauge for third gauge
1270 Views 9 Replies 5 Participants Last post by  sbjones0112
I had a electric gauge that went blank installed from previous owner. I am going to go with mechanical gauges in a three gauge pillar pod, but its a manual transmission. Boost, EGT, and then???? I was thinking about fuel pressure or Rail pressure. I am not racing or pulling so I think fuel pressure would be better.
Any suggestions?
Thanks
Chris
1 - 10 of 10 Posts
Lift pump psi...
thats what I was thinking about when I said fuel pressure.
thanks for your input
Chris
Yep lift pump pressure I would put in a oil pressure gauge though. Just to be able to seethe difference between the actual and the fake truck gauge
Sent from AutoGuide.com App
Oil pressure is one of the most important gauges to add. The dash gauge is a fancy idiot light.
ok so oil pressure, fuel pressure, EGT, boost, I need one more gauge.
Chris
U could run a rail pressure or better yet maybe run one egt on the rear section of manifold and another one monitoring the front four? That's kinda what I always wanted to do. And would do if I was in need for another gauge to fill a hole. Or both and run a triple pillar and triple overhead.
Here's a triple overhead pic for reference. I think they are really nice
Vehicle Car Rear-view mirror Automotive mirror Vehicle door
Gauge Speedometer Measuring instrument Tachometer Auto part
I have a old gauge pod that goes under the AC vent controls. but I like the pillar so I will run six but one is for my rear Airbags.
Looks good in the high mount though.
I have a 3 piece manifold that I was going to swap instead of the weird 2 piece. So I think I should be good with just one EGT.
Thanks
Chris
Rail psi is nice for monitoring and Diagnosis if anything goes wrong!
I have been contemplating gauges for a while now. I think for me. have an 06 with a manual. I will be running egt,, boost, maybe oil .....all three uptop by the mirror. and fuel rail and lift pump down by my shifter. I like the thought of monitoring both fuel pressures. because what usually fails or causes failures ? fuel pressure causes a ton of problems, and would be nice to see it and use it for some diag if needed.
just my thoughts.
1 - 10 of 10 Posts
