Shibby Engineering XRT/BlackMaxx Plug Set
Do these just plug up all the connections and loose ends when doing deletes? I almost have myself talked into deleting, I just wonder what to do with the pressure sensors between the DPF's and the servo on the cooler?
yep, that's all it does. Prevent damage to the connectors in case you want to reinstall dpf down the road. Might also prevent weird errors with the tuner due to exposed connectors. I bought a set, thought it was worth the money.
Reactions: cpobst
They are designed for the 07.5-09 trucks as the '10-'11 has two extra sensors. You can still use them but you will be short two plugs depending on how much of the exhaust (downpipe) and if you do the egr/cooler delete.
James
RSD
Reactions: cpobst
