I bought the truck with a lift and i have vibration. well i was going to put some shims on the carrier bearing but when i went under to check it out and do some measuring, looks like theres already a shim in there??
can yall take a look...do i already have a shim on or is that what it looks like stock.
There different shims that can be used. Its trial and error. If you have a vibe, you add or subtract shims till the vibration is gone. My shim kit came with over 10 shims to play with
how r u checkingur u joints? mine felt ok until i took the driveshaft out of the truck and it was apparent then that they were marginal at best . new joints and carrier bearing and wala no more problems.that spacer looks about right 4 a 6" lift, soooooo?
