I should be getting my 100hp injectors any day now, and I know that the next thing I need is a clutch. I will be getting an adrenaline w/pulse after that, but what clutch should I get? About 50% of the time I pull 12-15k lbs, but I occasionally pull up to 24k (just to jump my dozer from one place to another). Do I need a DD or can I get away with a single? Also, do I have to upgrade my NV4500 or will it be ok as long as I'm not to rough with it? Thanks
If you want to have some fun get the DD but the single will work it just a little grabby
What single should I get to hold the 100hp sicks and the adrenaline pulling heavy loads like this? Is there anything else I should do? I need to go as cheap as possible and still be reliable.
A south bend con fe would hold but it would be a hell of a ride backing up a trailer.I would go DD and never look back.You cant do any racing and sled pulling with a single, u will melt it.Thats a pretty heavy load you pull, so you cant slip a single,it either in or out
Crayola spokesperson
ya if your pullin that much id get the dual disk it will make our start out so much easier and backing up problley 2
I agree, when i went to get my truck i had no idea how to drive a stick and think i melted the con fe on the way home. I had to drive 400 miles to get it. So with that being said i got the 3850 from south beend and love it, easier to drive, but you will also have to get upgraded hydraulics also. Well worth the money in my opinion :thumbsup:
Do I have to upgrade the input shaft or will it be ok with the power I will have? A dd is about $1200 and hydraulics are about $250, so that is $1450, that will take me a while to save up for it. Would you reccomend the SB DD 3250 or 3850 or what?
