1 - 13 of 13 Posts
in need of new clutch what to get? needs to hold 550+ hp daily driver,may hook to sled few times a year,be on drag strip afew times.Which one will hold up!:confused013:
i think im going with the southbend single disc rated at 550... i just need to know if it need hydraulics.... also the 3600 dd is great just depends on what u need it for... i was looking into valair but a friend that owns sauer disel performance told me hed never own another one :confused013:
Valair Clutch
valair. if you plan on hooking to a sled and raceing id prolly get the 3650 from them. i personaly run the 3850 but it can be kind of grabby
and to open this back up.... who has had problems with valair
I had great luck with South Bend when I had my other truck. Pedal pressure was lighter and it hooked up and did not complain when I was at 30,000 running over the pass.
The only thing that was a little bit of a pain was it grabbin when I was loaded and using reverse to move around in tight areas. I put a 2wd low range switch in which pretty much took care of that problem.
Banned
Valair Dual Disc 3650# or 3800#
Discussion Starter · #9 ·
How Is Pedel Pressure With Sb Or Valair
Shiftin Fool
my personal opinion is to go with a South bend 3250 12 cb DD. it will hold up to the sled pulling and the drag racing and also will be great on the street. it will also be able to handle more power when you decide that 550 isnt enough. which you will!
Banned
I'd go larger than a 3250#
Discussion Starter · #13 ·
shot me some prices thanks
1 - 13 of 13 Posts
