1 - 20 of 70 Posts
just put my boost and egt gauge in... just wondering which boxes i should buy since i have mechanical gauges and which box first??? my brother in law just got his adreneline and i don't want him to kill me
dont need a display already have gauges not gonna switch
u could get the edge comp because you still use the manual guages
You don't have to use the gauges the Adrenaline comes with. Just don't install them???
It is still priced comparable with any other wire tap box that makes decent power except you can still have a TT, High Idle and cold engine protection, which none of the wire tap boxes have unless you buy a monitor to go with it.
That is why we offer the Adrenaline without the monitor.
Tech Specialist
I'll say this, my adrenaline hands down beats the TST Competition/Smarty I used to run and the Drag Comp I ran for a little while. It fuels harder, has higher boost, lower egts, it's cleaner, it's smooth yet brutal, and it'll actually spin these 35's where as the other two wouldn't. I'm very, very happy with it.
Discussion Starter #13
the adreneline will take it off there.... so qzilla you all offer the adreneline without the gauges and it works the same, so does it come with a knob to switch power levels
Just wondering how the adrelinane will take it off since it doesnt load onto the ECM and the Jessup tune does? You need to get returned to stock before adding the ADR.
Go for Broke
i have the comp and adrenaline....they both work well but i would say the adrenaline will put a bigger smile on your face...and the tunes are easily down loaded from Quad's web site and the Customer service is top notch :thumbsup
does everybody hate the redline. I run a redline stacked with edge. never had problems and for street driving its fine untill like 2000 plus rpms while freeway cruising but in my opinion just run the edge box untill you need to smoke somone out or beat up on a ricer...lol.
Discussion Starter #19
i beat up on ricers already just like my name says!!! i want the best going to upgrading my turbo before the end of the year also
Discussion Starter #20
so if i dont get the jessup tune taken off what will happen
1 - 20 of 70 Posts
