I tow sometimes 12-14K lb I want it to be more leveled out... what sort of airbag set up should I go with I want versatility so I can deflate and air up my tires too.. let me know what you all think thanks in advance
It is easy to do yourself. I put a set of Firestones on last night with the compressor. Easy. I got mine used off of Ebay cheap. You can get them new online for $220-250 plus the Air Rite compressor kit.thanks dom and scrambler I appreciate it I talked to BIG 0Tires and they quoted me for the new AIR RIDE set up compressor, accessories, and everything for like 1000 bucks... I am pretty sure I want to do them myself.. what do you think.
Have you seen the carli long travel bags yet? They get rid of That apacer under the bags. I ended up bending both mine after a while. I switched over to the carli and love them they don't ever come close to bottoming out the bags and ride a million times better than the firestones did. I know their pricy but well a must for a lifted tower. Truck looks clean.:beerthe firestone bags would probably be your best bet....it's the most common. and most shops will have them in stock for your truck. i have them on my truck with a spacer, because i have a 6inch superlift rockrunner kit on my truck......
Just got back from pismo beach ...i towed a 14000lbs rockwood trailer out there and the bags did there job. i had the pressure set to 'bout 55lbs and pulled that trailer with no problem...i love the firestone bags. i highly recommend them.
my set up is the same as the previous guy. just have them going through my license plate holes..:thumbsup
i have a built in power inverter in the back of bed... and just carry a compressor w/ me when i know im going to need it for heavy load.....other then that i drive around with 'bout 6-8lbs in each bag...
