Do the turbos spin freely? Did you take the turbo guts out of the exhaust housings? If so is everything tight?
I pulled the boot off and spun the compressor and it spun freely... How do you pressure test?Seems to me, you need to check everything one more time Jerry. Have someone build boost stopped and see where it is coming from. Or you can make your own intake pressure test.
Maybe when you clocked the turbo. The impeller isn't set right and doesn't want to spin freely.
No, I had to remove the intake horn to install the heater grid delete. When I reinstalled the intake it woulndnt sit flat so we had to grind it down a little to sit flat.So you had you remove the manifold? That was a pain to install...
