1 - 14 of 14 Posts
I have searched around and couldn't find an answer. I am looking at water meth kits and the price between stage 2 and 3 is quite a bit. Along with many stage 2's for sale in the classifieds. I know the site says stage 2 is only good to 25 psi and stage 3 is more. My truck runs at 40 or so going down the strip (my main reason for meth) and I didn't know if stage 3 would be worth the extra $ vs. 2 Future mods will be a super b special and injectors no bigger than 90.
I would love to know myself, also check out devilsown water meth, price is a lot cheaper
Stage 2 for diesel application has a module that will work with pressures up to 100psi. You dial in beginning stage of meth injection and full flow. Mines is set at 17psi start and full flow at 40psi. The stage 3 monitors egt's and can use egt's for meth injection, plus it had a much larger reservoir, and an egt gauge. Hope this helps.
I've looked at some devils own kits. Which one's are you guys running for higher boost. there was a stage 1 and 2 stage 2's on their site.
· 3 footin' through life
Subbed. I've had similar questions. My feeling from their site is that the controller for the Stage 2 is a bit more rudimentary. Being able to spray with EGT control seems like an option well worth it.
Devil's own meth kit looks identical to Snow performance, but less priced.
Stage 2's look similar but they don't have a stage 3 with egt based injection. Also, none of their kits come with resivoirs. Thats worth $100+ right there.
I like my stage2 snow. I dont see having to make any changes once u have it set. As for resivoirs just go to a shop that builds rigs and they should have some 1 gal. fairly cheap. Also mine came with 2 different size nozzles for different power levels. Hope this helps
I had a stage 3 snow on my 01 and loved it. You have a monitor in the cab and can control the injection rate off of boost or EGT. You can control how much you want injected at whatever pound(s) of boost or at whatever degree of EGT from 33% to 66% to 80% to 100% or something along those lines. Never had a stage 2 or 1 but sure did love that kit on my 01. I bought it used for 500 on here a while ago. You can get whatever size tank you want online also I had a 7 gallon on mine. Hope this helps a little bit.
Discussion Starter · #11 ·
I will only be using it for 1/4 mile runs and running hard on the highway. Can I put a switch on it so I don't have to worry about it spraying when I don't want it? I think I will go with the devils own because I plan on tapping into the windshield resevoir. Also I want to get the most out of the stage 2 devils; will it come with all the nozzles or biggest nozzle or do I need to get that seperate?
Devil's own kits are great! I have had one for 35000 miles and 5 harsh winters and it still works like new. The kit they offer for the diesel has 2 injectors and you can always get bigger ones in the future.
Reactions: jaslater
Ya I just ran a toggle switch with mine, and im not sure about the devils own nozzle sizes.
You do not need a toggle. When I don't want mine to spray I simply turn the controller to the max on both dials and it won't kick in then. They have a base set of two nozzles for the diesel kit if you need bigger sizes or are unsure about sizes just shoot them an email and they will size them for your needs.
1 - 14 of 14 Posts
