1 - 4 of 4 Posts
Ok guys so I'm changing my belt and tensioner and noticed my water pump is starting to weep and leak a bit of coolant. Miswell change it while the belt and everything is already off. My question is do I have to drain the coolant down so when I pull the pump out, coolant doesn't come flowing down, or just pull the 2 bolts and pull the old one out? Just curious as to what you guys who've done your water pumps before have done, Thanks! :S:
You need to drain the coolant first, but your still going to have a bit pouring out when you remove the pump.
Thanks all for the input...got the new one from napa put on and was still dripping out the weep hole so had to take it back off and get another replacement and now we're all good to go :thumbup:
1 - 4 of 4 Posts
